Home > Detailing & Car Cleaning > Lugging the country side around in your Sport.
Brit Plumber
I have spent the last 4 weeks slowly removing trim and other parts to remove the unsightly remnants of a Matt black wrap that was applied to my car. Every panel has this crap just around the edges where it’s been pulled off but it’s all paying off with a much tidier looking car. I pulled off the black wheel arch trims that are under the back door and found a s!*$ load of English countryside built up inside. Looks like a rust trap in the making so I may think of a way to put a drain at the bottom.
The right side lump fell out.
The left was wet and stayed put.
So I set everyone a challenge to see if anyone has more of the country side than I, and to clean this trap out before the rust sets in. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #557615 Mon May 28 2018 8:38pm
Try taking it off road in sloppy conditions and then you'll see how much countryside can really build up in these places. I reckon the last time I did a full decoke on my previous RRS, I lightened it by enough to plant a row of spuds in! 2012 SDV6 - it's missing a couple of cylinders
Post #557617 Mon May 28 2018 9:22pm
TrafficMan
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Lux Stornoway Grey
I'll check mine tomorrow.
Post #606427 Sun Nov 08 2020 9:38pm
