Home > General > suspension will raise when cooled ..Help |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4396 |
Either a faulty temp sensor on the compressor or a wiring issue to said sensor |
Sun May 13 2018 2:55pm |
stebenny Member Since: 15 Dec 2013 Location: leyland, Lancashie Posts: 120 |
As always thank you, Is it safe to drive till i can get it looked at |
Sun May 13 2018 5:27pm |
If the car is lowering over night it may be that you have an air leak and the compressor has burned itself out trying to maintain pressure. Does the temp warning come on straight away or after 5 mins or so ?
Mon May 14 2018 3:57pm |
