![]() | Home > My Range Rover Sport > Had my alloys refurbished and now gunmetal grey. |
kismet110 Member Since: 09 Oct 2010 Location: London Posts: 382 ![]() ![]() ![]() |
Look good! What colour were they before? |
Jampot1979 Member Since: 23 Jun 2017 Location: Bedfordshire Posts: 145 ![]() ![]() ![]() |
They were the standard silver. |
Pinnacle Member Since: 13 Mar 2018 Location: Romford Posts: 72 ![]() ![]() ![]() |
Is that an after market suspension. How you get your RRS to go so low?. I can't get my that low in access mode. |
Standard suspension... Maybe the pics make it look lower. 🙂 |
Maybe it's the autobiography bumpers that makes it look lower. |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
Looks great. IT`s an HST isn`t it, not AB?
Sometimes when I try to put mine in access it says suspension extended mode and starts rising again. |
It will try to go extended mode if the under car sensor detects something that triggers the suspension ECU think the car will bottom out or get hung up. Have you checked under the car that there isn’t something loose or have you driven over something and dislodged the sensor? Or have you had some work done on the suspension - even had new wheels/ tyres fitted recently, that might have disturbed the level detectors? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Yep. It's an HST ![]() |
Are those 20`s? Steve. |
Yep. 20's. |
Yeah I put 22" on. but it did that with the 20"'s on as well. |
airc909 Member Since: 28 May 2018 Location: Coventry Posts: 112 ![]() ![]() ![]() |
those tyres look chunky |
