Home > In Car Electronics > Aerial
Bobby7943
2005 Range Rover Sport TDV6 HSE Zermatt Silver
Aerial
My roof aerial on my 05 sport seems loose and not flush to the roof how do I access it to tighten it up
Post #555391 Sun Apr 29 2018 6:57pm
Remove C Pillars inside. Where the seat belts emerge from.
Get 2 long big screwdrivers.
Ease the headlining away from the boot seal.
In the middle of the headlining there is a metal bracket holding the headlining to the roof.
Put the two screwdrivers into the metal bracket holes and pull down to unclip it from the roof.
You may need to remove to interior trims by the rear doors. In which case there is a torx bolt behind the airbag badge
Post #555396 Sun Apr 29 2018 7:12pm
Bobby7943
Many thanks I take it something needs tightening up
Post #555400 Sun Apr 29 2018 8:05pm
