![]() | Home > General > Still won't warm up |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
Picking out one bit of your symptoms list this sounds really strange, and thinking allowed..... As I understand it, when you stop a car the reason you have to leave it before undoing the rad cap is the engine is still hot but as water is not circulating the water in contact with the block will effectively boil and create pressure which will force hotwater out through the cap if the pressure is released this way by undoing. So as there is no pressure under your cap the water temp has not reach 100C even when you’ve turned off the engine. So it is running too cold. Reasons why? Thermostat always fully open? This should regulate temperature to a preprogrammed setting and if not closing it does not allow the engine to reach that temp. Presumably the RRS thermostat is the same old fashioned ones involving wax contained within a chamber and when it gets hot the wax expands and forces the thermostat open. So first question; is it closed before you fit it? And question 2; does it open if you put it in a saucepan of boiling water? Don’t do this if it’s not an old fashioned mechanical one as described above. Alternatively is the cooling fan working too well? You probably know and have thought this through already but just my musings on your problem for what they’re worth. Also have you considered temporarily blanking off the radiator with a bit of cardboard just to see if you can get it to run hotter at lower driving speeds? Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
It still sounds as though the stat is partially open don't think there are to many other options left if you can get hold of an infa red heat gun and measure the hoses either side of the stat you will see what difference in temp's you have before and after the stat at any given time i think thats your next port of call |
Bullnogger Member Since: 29 Mar 2016 Location: Stoke on trent Posts: 81 ![]() ![]() ![]() |
Firstly thankyou for the replies much appreciat
