![]() | Home > General > Strange vibration when idling |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5063 ![]() ![]() ![]() |
Sounds like a issue with air suspension compressor, might be a leak somewhere causing it to run that often, as that is the location of the compressor.
Bullnogger Member Since: 29 Mar 2016 Location: Stoke on trent Posts: 81 ![]() ![]() ![]() |
Noise coming from compressor
Wakerz Member Since: 30 Mar 2018 Location: Leicester Posts: 12 ![]() ![]() ![]() |
Thanks for the reply Bullnogger. Any idea what the actual problem is?
It could be a number of things
Thanks a lot. That’s really insightful.
