Home > General > Any water coolant or range rover coolant
alsayyed
Qatar
Hello friends , I have a question for 2014 range rover sport super charged regarding water coolant in radiator. Do I have to stick to the water coolant that supplied by the range rover dealer or I can put in type water coolant in the radiator.
Thank you
Post #553981 Fri Apr 13 2018 8:03am
scarey
put the same colour in..if you have red then put red in , blue for blue.....
and any make will do ..
Post #553982 Fri Apr 13 2018 8:07am
alsayyed
Qatar
thank you for answering my question . I have put Ac Delco before and temperature went up. then took the water out put regular water and it is perfect temperature normal in the middle but this tap water not advisable for the, i will change the water and pour a AC Delco again I do not know what was the color,
Post #553983 Fri Apr 13 2018 8:12am
I would expect it to be orange. OAT 5 year
It's not advisable to use 100% water as the coolant contains inhibitors to prolong the life of the head gaskets and water pump etc...
Use 25% coolant 75% water to prevent over heating.
in places where there is no risk of freezing.
or refer to the instructions on the bottle
Post #553993 Fri Apr 13 2018 10:24am
