![]() | Home > Faults & Fixes > RRS 2010 5.0 Supercharged strange coolant leak |
davidfo Member Since: 12 Apr 2018 Location: Berkshire Posts: 9 ![]() ![]() ![]() |
My RRS has a strange coolant leak, that only occurs around the Coolant Expansion tank, and only when I put my foot down.
Thanks, it's only under load when I put my foot down, steam out of the uk nearside front bonnet. Open the bonnet and there's coolant spray around the expansion tank area.
Was it bled properly as these are bad for getting air locks |
That's a good question, I am hoping it is this and the Undue mentioned it did have an airlock. What's the best way to bleed these beasts?. |
Have a quick search on here it should be explained |
So after bleeding the system I still have a leak. It only happens when warm and when putting my foot down and seems to come out of the coolant return pipe or connector?, on top of the nearside of the engine. I replaced the original clip with a jubilee this morning thinking it was the clip, but maybe there is a rubber seal in the plastic connector, or it is leaking from the plastic connector going into the supercharger? - see pic...thanks. |
Just to respond to my own message, I still have a coolant leak to my dismay, however, thought I would post back to advise I was sorely mistaken thinking the pipe clip I replaced was a coolant pipe. After tracing the pipe further, it was a pipe that went into the intake in the front of the engine.
