Home > Technical > air bag light on
Alfa Rover
Canada
air bag light on
Hello Gents, got an air bag light coming on intermittently . B0091-81 (AE) Left side restraints sensor 1 - Bus signal/message failure - invalid serial data received. this is the code i got using the gap tool. any help is greatly appreciated. the clock spring fix was done at the main dealer years ago under previous ownership. correct me if i am wrong but according to the code am i supposed to look at the left side seat belt latch electrical connector? i have read some threads which state to loosen and re tighten a connector under the seat. if any one can help to point me in the right direction would be great. any photos and instructions and precautions would also be welcome. eg disconnect battery so the air bag does not blow up ect...
2006 range rover sport hse 4.4 l engine Canadian model.
Cheers Neil.
Post #553763 Wed Apr 11 2018 3:02am
Not sure if this is of any use, taken from Workshop Manual,
B0091-81
Left Side Restraints
Sensor 1 - Invalid serial
data received.
NOTE: Circuit reference LH
SIDE SENS F1 / LH SIDE SENS R1
Left side impact sensor 1
circuit open circuit.
failure.
Refer to the electrical circuit diagrams and check the left side impact sensor 1 (door) circuit for open circuit
fault.
Install a new left side impact sensor 1 (door) as necessary.
Post #553764 Wed Apr 11 2018 4:05am
Alfa Rover
Canada
Hello Col, thanks for the quick reply. Thumbs Up i don't have a workshop manual, next on the wish list. ok , by the sounds of that i guess i am looking for an impact sensor. location left hand side front door? i will google the location to see if i am correct. thanks for pointing me in the right direction. if you uncover any more information please post as this air bag light seems to be quite a common problem. of course the air bag light can be triggered by many other sensors and pin pointing the exact cause can be frustrating. Col thanks again for your help, i will post my progress. Cheers Neil.
Post #553766 Wed Apr 11 2018 7:04am
Neil,
If you pm me a email address I can send you some wiring diagrams as well that may help. There are at least three L/H side impact sensors, Front Door, "B" post and "C" post, hopefully it is the door one, as the code points to that.
Post #553769 Wed Apr 11 2018 7:34am
Alfa Rover
Canada
Hello Gents, first off thanks again to Col, just a update to the air bag light. after looking around for some time checking connector plugs ect. i have traced the fault to the drivers door harness. whilst opening the door with the engine running, the air bag light came on and the chime also was on as well.
next move will be to figure out how to access the connector at the door. may have a poor connection. if anyone has any advice or has done this as well please chime in. i really could use the help.
Cheers Neil
Post #555974 Tue May 08 2018 4:15am
Marcin2112
Poland 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Col wrote:
Neil,
Please send me front airbag sensor harness wiring diagram for rrs sport 2014, my email: marcinciesielski.jw@gmail.com
I have a broken beam from the right sensor and I do not know how to connect it.
Thank you very much and regards
Marcin
Post #616716 Fri Aug 20 2021 7:58pm
