Home > Tips & Tricks > Side Steps - Protection of Aluminium Trim
Evo5man
United Kingdom 2013 Range Rover Sport SDV6 HSE Lux Orkney Grey
I fitted a set of side steps last year and have noticed that the aluminium trim is starting to get marked on the leading edge from stones and road grime thrown up from the front wheels. I have tried various methods of cleaning but decided that some form of protection was required to prevent further damage.
I decided to try applying some 3M paint protection film to the leading edges of the trim. I am please with the results and the film can only be seen if looking very carefully at the trim finish. The original aluminium trim has a satin finish and the 3M tape has a gloss finish.
The film is easy to apply, just keep it wet with a mixture of water and washing up liquid, this allows you to slide the film around on the trim until you have it correctly aligned. Then just use a plastic card to squeeze the water from behind the film and that is it.
I will provide an update in the Autumn to see how effective the protection is Thumbs Up
Post #553424 Sat Apr 07 2018 5:04pm
dobbo9
Good job. Great solution.
Post #553429 Sat Apr 07 2018 5:28pm
Eaters
Yes. Interesting. Just got to get mine in a condition where they’re clean enough to warrant protection. Very Happy Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #553452 Sat Apr 07 2018 9:56pm
Cymruambyth
Wales
Why not put it on the whole length? Protect it all then Very Happy As said, I`d need to get mine half decent to bother with this. Steve.
Post #553491 Sun Apr 08 2018 11:04am
PDC
I thought that I was the only one that had this problem. They really are a Censored to keep clean!!! Big Cry 2010 RR 5.0 Autobiography
2020 F-Pace SV
2018 RRS HSE Dynamic 3.0
2015 Disco XXV
2011 Disco 3.0
2008 RRS HST V8
Post #553500 Sun Apr 08 2018 11:25am
Eaters
I did try some T-Cut and then some rubbing compound which did improve it quite a bit but there are still, what appears to be ingrained marks left. Next step will be fine wet & dry I think Robin
Gone:
MGZTT 190 2.5
Post #553502 Sun Apr 08 2018 11:48am
Evo5man
Hi Cymruambyth,
Yes, that would definitely be an option to cover the whole length but it is only the leading edge of the aluminium cover trim that seems to be a problem on my side steps. From a visual perspective, it is not obvious that I have only covered the leading edges, I had to take a lot of photos from various angles to get it to show up in the pics!
I will monitor the trim over the next 6 months and if necessary, will cover the whole trim length before winter arrives Thumbs Up
Post #553503 Sun Apr 08 2018 11:49am
Tyrefitter
While we are on the subject of sidesteps,,,,ive just replaced mine after having them colour coded last week by a friend who’s a paint sprayer.
Andy. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #553513 Sun Apr 08 2018 2:03pm
Evo5man
Looks good Andy Thumbs Up
If my 3M protection film does not 'hold up' to road conditions, colour coding will be my next option Thumbs Up
Did your sprayer mate take the aluminium trims off and paint them or mask the steps up and paint the trims while still attached to the steps?
Steve
Post #553514 Sun Apr 08 2018 2:10pm
Tyrefitter
Steve,,mine are aftermarket steps & the trim is only riveted on & is metal not alloy,,so i drilled the rivets out removed had them painted then refitted this morning.I put a coating of Gtechniq C5 on yhem thurs for extra protection
Andy Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #553515 Sun Apr 08 2018 2:21pm
Paulcp
2013 Range Rover Sport SDV6 HSE Atacama Sand
A thin coating of ACF50 every few months over 3 years and mine were almost like new when I sold it after 40k miles
Post #553536 Sun Apr 08 2018 3:48pm
Tyrefitter
Just the vents to do black & tint the front windows & all will be good.
Andy Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #553542 Sun Apr 08 2018 4:40pm
Cymruambyth
Wales
You`ll need to look out for plod if you tint the fronts Sad Steve.
Post #553550 Sun Apr 08 2018 5:39pm
Tyrefitter
It will be ok,,they will give me a form to take to MoT station after ive removed it to get stamped,,,,,,ive got a mot station Laughing Laughing
Andy Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #553556 Sun Apr 08 2018 5:57pm
Cymruambyth
Wales
I think they usually make you take them off at the roadside Thumbs Up Steve.
Post #553574 Sun Apr 08 2018 7:27pm
