Home > Technical > Do I need to change impact sensor |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4976 |
shouldn't need to |
Sat Apr 07 2018 9:21am |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849 |
That’s a difficult one to say really. You would need to check it hasn’t been damaged and I would be doing a current check at the connector to make sure there was nothing before removing the battery to fit the wheel. And when fitted, I wouldn’t sit in the drivers seat to turn the ignition on for the first time....just in case. 2019 5.0 SC SVA (Current)
Sat Apr 07 2018 3:59pm |
