Home > Orders (L494) > front sensors
denny111
front sensors
I have a new 2018 car
Is it possible via settings to permanently enable the front parking sensors rather than pushing the sensor location on the touchscreen
Thanks
Post #552116 Fri Mar 23 2018 5:45pm
Tim in Scotland
There was a software patch to fix that in 2016 cars, odd that 2018 cars are suffering the same issue. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #552121 Fri Mar 23 2018 6:40pm
Eaters
If you select reverse first doesn’t it switch on both front and rear sensors. It does on my 2008 Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #552122 Fri Mar 23 2018 6:47pm
denny111
yes it does but l dont want to select reverse first
Post #552181 Sat Mar 24 2018 11:46am
syl
There's an option in the settings for MY17 (enabled below 9mph I believe). RRS MY17 SDV6 AB
Evoque MY17 TD4 AB
Post #552184 Sat Mar 24 2018 1:13pm
denny111
menu different in 18 models has anyone achieved it in an 18 model?
Post #552196 Sat Mar 24 2018 4:07pm
Dave777
Even the MY16 ones with the software patch don’t always stay on sadly. MY16 3.0 SDV6 Autobiography in Aleutian silver, stealth pack and toys.
Post #552208 Sat Mar 24 2018 8:14pm
Eaters
Hmm. It is yet another "improvement" introduced by the spotty nosed boffins which seems to be change just for changes sake and turns out to be a retrograde step (like key-less entry/ignition). The button on the dashboard on mine works just fine. At the traffic lights, if its still on, I can turn it off with one push to stop it squarking all the time, as I can when off road to avoid it picking up every bush or hillock. Robin
Gone:
MGZTT 190 2.5
Post #552233 Sun Mar 25 2018 10:14am
