Home > General > HDC Fault and grinding noise from underneath |
It could be either a brake has bound on or the Electronic Parking Brake has corroded on. I get the latter every time I leave my car outside on the drive for more than 3 weeks - as I work overseas a lot that means I come back to the car 99% with a bound on Parking Brake and therevis no way to leave it disengaged as it will automatically engage on both L320 and L494 RRS’s after 10 minutes. The HDC fault could be caused by that too as it monitors wheel rotations on each wheel. I don’t know why it would cause the suspension to lower though. It could be that you have a leak in one of the suspension doughnuts or the heat from the bound on Brake is causing a problem for the suspension 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri Mar 16 2018 10:19pm |
Flinders Member Since: 12 Dec 2014 Location: West Yorkshire Posts: 126 |
Thanks Tim not thought about the brakes sticking on. Thank you. It moves forwards but it makes the awful noise. I think we are better getting it to the garage rather than just replacing the battery. Typical... we have had the car 3 years waiting for snow and in the Beast from the East dumping a load of snow the RRS is parked up ...broken! With another dumping of snow due this weekend the X6 is certainly being tested in this snow while our RRS girl sits watching the world slide by! Lol! |
Fri Mar 16 2018 10:28pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8976 |
Not on a 2006 L320, Tim. Perfectly ok to leave it in Park without the EPB engaged and it'll sit there as long as you like. If the vehicle is being left for a period of time on a level bit of ground, I'd leave it in Park without the EPB applied. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Fri Mar 16 2018 10:58pm |
dotty Member Since: 11 Sep 2014 Location: St Heiler Posts: 52 |
Did you get this resolved? I have the exact same issue.. |
Thu Jan 10 2019 5:02pm |
Hi Dotty we did resolve this after trying a few things. First we changed the battery then the brake switch. The faults were still there and the grinding noise too. Left her parked up for a fair while until we took the plunge to take her to the garage expecting a massive bill for compressor or something worse....
Thu Jan 10 2019 10:21pm |
