Home > General > lean when cornering and suspension lying down
sport2007
United Kingdom 2010 Range Rover Sport TDV8 HSE Rimini Red
hi all
I have just bought 2010 hse 3.0 and the lean when cornering warning has come on even when driving on the motorway and when the rr is parked the suspension drops way down but only at the front. it rises ok once started. the mechanic tried to tell me they all do that until I told him that I have owned one for the last 4 years and that it never happened once. any ideas please
ta
Post #550787 Thu Mar 08 2018 3:39pm
james5599
I had the same fault on an early Range Rover sport - it was diagnosed as the suspension air pump iirc . Car was under manufacturers warranty but it was a 2 grand part as I recall. Same symptoms as you mentioned. But this was 13 years ago so I might not have the exact details correct.
Whatever the mechanic is telling you doesn’t sound right at all. 2019 Svr and 2019 R35 GTR
Post #550792 Thu Mar 08 2018 4:38pm
Cymruambyth
Wales
Re: lean when cornering and suspension lying down
sport2007 wrote:
hi all
ta
Do you mean this light?
 Steve.
Post #550803 Thu Mar 08 2018 6:13pm
first thing to do is change the seals in the front air block . (and clean it out)
£15 off ebay
See if that stops it dropping over night
or remove a 20A suspension fuse from under the bonnet, before going to bed and seeing if one corner is lower than the other in the morning
Post #550808 Thu Mar 08 2018 7:11pm
