Home > Technical > Passenger front window randomly opening on it’s own
Ribcraft
United Kingdom 2007 Range Rover Sport TDV6 HSE Santorini Black
My 2007 2.7 tdv6 HSE front pasenenger window opens randomly on it’s own, there is no pattern when or where it decides to open, engine running or not (ignition on). It opens all the way down unless I stop it with the button, it closes again no problem most of the time, sometimes it only goes up a few mm and I have to keep pulling button up and then it goes up all the way. I’ve tried holding the button up for one second after closing to reset anti trap but nothing. I’m wondering if it’s the anti trap playing up, Can I disconnect this anyway, where is it located?
Any advice would be appreciated
Post #550599 Tue Mar 06 2018 8:45am
gogsy1956
I've just had similar problems with my drivers window,, every time I tried to close it it would open after reaching the close position. Tried cleaning the window,, especially the top edge and the seal on the door. Wound the window all the way down then inched it up until it was fully closed then kept the button pulled up for a few seconds and it seems OK now. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #550603 Tue Mar 06 2018 9:41am
