![]() | Home > Wheels & Tyres > New rims |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
Why not just buy another set of sensors and fit to the new rims ?, or alternatively as the TPMS system in a RRS1 is pretty useless anyway, why not just de-activate it in the CCF files.
Hamtheman Member Since: 18 Jan 2017 Location: Joburg Posts: 33 ![]() ![]() ![]() |
Yup was thinking along the same lines, TBH the TPMS on my RRS (2011) is pretty much spot on with no errors.
The car should recognize the new sensors automatically, If I remember correctly just fit the wheels leave the car for a few minutes, then drive car and once you have done a few Km's over 20mph it will automatically code them. When you fit the new sensors make a note of the serial no. of each one and wheel position so if there is a problem you can get them coded to the car using a diag. tool.
Thanks Col, the TPMS here is the same here, no actual reading just a warning on low pressure . I like that as on a long gravel road it warns you of an issue before you completely destroy the tyre. |
