![]() | Home > My Range Rover Sport > Access mode red flashing icon on 4x4 info screen |
Have a look on the 4x4 screen to see if you got any red icons on one of the corners that will give you an indication if you have a height sensor issue |
RRSROBBIE Member Since: 06 Feb 2018 Location: Gloucester Posts: 5 ![]() ![]() ![]() |
Thanks for the reply.. i have a red icon on the front right wheel only occuring in Access mode.. in standard mode though the icon is white but still sits slightly lower than the other 3 white icons on the 4x4 info screen if this helps.. cheers |
I think thats the issue then may be a wiring fault or a sensor height best to get codes read if you can to be sure |
A few folks on here do mobile flushing |
Thanks mate.. who and how much is this service👍👍 |
Try woody32 on Disco3 and on maybe on here over in Taunton i think a lot of people use him pm for a price |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
Ooooo, good to know. Steve. |
So I've finally been able to get the RRs in to a local specialist and it looks as though it is a height sensor issue.. so this will be done along with a calibration tomorrow. they have also told me that once work has been carried out they are gonna leave it over nite before handing it me back just to make sure the air bag on this side doesn't lower or deflate as some times this happens after a height sensor has been replaced.. does this sound right?? |
