![]() | Home > Technical > RECOMMENDED TYRE PRESSURE LOOK-UP? |
wokkaman Member Since: 08 Nov 2006 Location: GU34 Posts: 761 ![]() ![]() ![]() |
Morning all, when I go to the RECOMMENDED TYRE PRESSURE LOOK-UP menu, nothing is there?? just (...) where the pressure should be.... is it a dealer thing? Cant see anything in the hand book.
Springer Member Since: 10 Apr 2009 Location: Peterborough Posts: 20 ![]() ![]() ![]() |
In mine (2017 HSE) you have to be in park to see the recommended pressures. |
ah - will try that later |
