Home > General > Restricted Performance
Muz
I have a 2015 RRS Autobiography which has been having a restricted performance message for some time now and has been at the garage since the 4th Jan this year. They have done the following - Replaced primary turbo and Replaced turbo shut off valve on secondary turbo and I had the car back for 9 days before the same thing started happening again. Any ideas how to repair as Land Rover appear to have run out of ideas?
Cheers,
Muz
Post #549160 Mon Feb 19 2018 2:35pm
Disco_Mikey
What fault code is coming back?
Post #549196 Mon Feb 19 2018 8:21pm
Muz
It is always the same and it is just ‘restricted performance’
Post #549197 Mon Feb 19 2018 8:33pm
Bullnogger
England 2007 Range Rover Sport TDV6 HSE Java Black
Module restricted performance came up on my range when
One of the connectors broke off on the transfer case control module
Due to water corrosion as well as lots of other faults
Hope this helps
Post #549207 Mon Feb 19 2018 9:36pm
That's not a fault code, it's a driver warning message. The fault codes are read through the OBD port and generate a code something like U0100-04 (made up code). Generic code readers don't get the last two digits which can limit their ability to pin point the problem. 2012 SDV6 - it's missing a couple of cylinders
Post #549219 Mon Feb 19 2018 10:45pm
