Home > General (L494) > Heated screen question
syl
Is there anyway to tell if the heated screen is turned on?
I know the heated screen control button lights up when pressed, and that it also comes on automatically below 4 degrees (and the button lights up), but I've noticed condensation on the screen, when I get I my car despite it being above that temperature, clear - with the button remaining unlit. The pattern of clearance is exactly the same as if I had turned it on (a bit at each side uncleared, together with a stripe right down the middle and another very thin stripe on one side where I believe an element is broken).
I'm wondering if my screen is coming on every time I start the car - or if it is even on permanently. RRS MY17 SDV6 AB
Evoque MY17 TD4 AB
Post #548735 Thu Feb 15 2018 6:45pm
Tim in Scotland
I have noticed the same thing on mine - even though the light is out it still seems to be heating the screen. The one way to find out is to go for a drive after dark and you will find that on coming car’s headlights are badly distorted when the heater is on. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #548771 Thu Feb 15 2018 10:27pm
Fletcher
I was going to say, I can see when mines on as it distorts your view slightly.
Post #548783 Thu Feb 15 2018 11:41pm
Cymruambyth
Wales
Ooooo, never noticed that! Steve.
Post #548785 Fri Feb 16 2018 1:16am
wilf
I understand that both front and rear screens can switch on automatically in response to certain conditions to keep the screens clear of mist/condensation.
The indicator lights may or may not come on under those circumstances.
I have never personally noticed any difference in terms of the optical qualities of the front screen between "on" and "off". That might say more about my eyesight than anything else, lol. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #548788 Fri Feb 16 2018 9:24am
Cymruambyth
Wales
I assume the auto on is only on newer sports? Steve.
Post #548822 Fri Feb 16 2018 3:59pm
wilf
I recall it happening on my 2010 Jag XF. So nothing new.g MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #548900 Sat Feb 17 2018 6:12am
Yes. Original RRS didn't do it, facelift did. 2012 SDV6 - it's missing a couple of cylinders
Post #548913 Sat Feb 17 2018 10:49am
