Home > Technical > TDv8 RRS and TDV8 FFRR
Tim in Scotland
Have been reading Land Rover Enthusiast mag today about the TDv8 engines in the FF and RRS - they are not quite the same engine......................... FF has no anti-roll oil pump, one driveshaft passes through the sump, on the RRS there is and also the alternator is differently located.The Sump on the RRS has caused problems as it wouldn't fit round the front diff too, the Turbos have had to be relocated to a different position because of the different shape of the Sports engine bay. Also the Sport version has a different exhaust system to make it sound more "raspy". 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #75456 Mon Jan 15 2007 6:58pm
tf9
Russia 2006 Range Rover Sport Supercharged Java Black
4.2 S/C engine is also a bit diffirent.. and rrs gets 390bhp while ffrr gets 398bhp.
FFRR even has better acceleration 0-100kph Smile 2014 Mercedes-Benz S500
2014 Range Rover Autobiography, Causeway Gray, Ivory/Ebony
2013 BMW 530d
2008 Range Rover Supercharged Vogue S\E, Java Black, Ebony. SOLD
2006 Range Rover Sport Supercharged, Java Black, Ebony. Arden body-kit. SOLD
2005 Range Rover Vogue 4.4 Buckingam blue, Ivory. - SOLD.
Post #75460 Mon Jan 15 2007 7:09pm
LRtuning
2006 Range Rover Sport Supercharged Cairns Blue
Engine maps in RRS and RR are exactly the same....pure marketing exercise by LR to separate the 2 models
Post #75479 Mon Jan 15 2007 8:45pm
rrsjo
Re the TDV8 - Doesn't the fact that the turbos are in a different position - and presumably both have different exhaust components, make a difference to the fueling requirements?
Have you chipped any yet and are there any figures available?
Post #75521 Mon Jan 15 2007 11:11pm
LRtuning
Hello,
I have all the original LR engine maps and there are no differences between the 2 models.
It may be possible that one models exhaust is less restrictive and therefore power is slightly higher.
I've only had 2 RR TDV8's on a dyno and we were able to produce an extra 70bhp and 140Nm torque :-0)
Post #75551 Tue Jan 16 2007 8:27am
rrsjo
[quote="LRtuning"
I've only had 2 RR TDV8's on a dyno and we were able to produce an extra 70bhp and 140Nm torque :-0)[/quote]
Whow! That's 338 bhp and 790 Nm then if you produced LR's published figures on the dyno before 'chipping'. I for one will be seriously interested - that is once mine finally does arrive - still months away. Big Cry
Post #75565 Tue Jan 16 2007 9:28am
