Home > Wheels & Tyres > New Compomotive wheels 😎
qcnr
Norway 2007 Range Rover Sport TDV6 HSE Lux Buckingham Blue
"Do you know what Nemesis means?"
Rolling with laughter Rolling with laughter
Post #546791 Fri Jan 26 2018 7:31am
Buckster
Rolling with laughter Awesome film Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #546792 Fri Jan 26 2018 7:37am
Diversurfer
Portugal 2007 Range Rover Sport TDV6 HSE Orkney Grey
Hi Buckster,
I am considering buying the compomotive wheels shortly. I am told I need to rotate the steel blocks bolted on to the caliper.
Did you have to do anything or the wheels just fit normally, what blocks are we talking about Embarassed .
I have normal brakes, not the Brembo ones.
Cheers,
Antonio
Post #560760 Thu Jul 05 2018 12:27pm
Buckster
Hi Antonio,
As you dont have the brembos they will go straight on. Its only cars with Brembos that you need to rotate the blocks on.
Best regards
Buckster Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #560763 Thu Jul 05 2018 12:43pm
Diversurfer
Thank you.
On my way spending........
Post #560765 Thu Jul 05 2018 12:50pm
Hodgie
Australia 2013 Range Rover Sport 4.4 V8 HSE Bonatti Grey
l494
Hey Buckster
Compos look great is your vehicle an L494 ?
I am trying to find the correct brake set which will take the compomotives
My vehicle is the sdv8 and am running 20s which are not so good in the soft stuff
Post #617131 Fri Sep 10 2021 4:00am
Buckster
Hi Hodgie,
No my vehicle is an L320, i run 4 pot Brembo calipers and discs from an L320 4.2 Supercharged.
For your L494 i dont see any reason why the early Brembo 4 pot calipers and discs wouldn’t fit your car to enable you to run Compomotives, as all these calipers and discs seem interchangeable. Ie my friend ran L494 big 6 pot calipers on his L320 so no reason you couldn’t do it the other way around and down size the calipers & discs to allow you to run smaller wheels Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #617132 Fri Sep 10 2021 6:35am
