Home > General > Parking sensors not working
Pauly14666
Ireland 2005 Range Rover Sport TDV6 HSE Java Black
Hello I have a 2005 rrs my parking sensors do not work iv only sensors In the rear none fitted to the front I have scanned the jeep and it says all the sensors are out and lost control with the instrument cluster could it be the parking sensor module that is the problem that's in advance[/u]
Post #545883 Sun Jan 14 2018 8:59pm
Wonder if it's had a replacement front bumper ?
What sensors is it complaining about
Post #545889 Sun Jan 14 2018 9:27pm
Pauly14666
When I scanned it it says that the four sensors are faulty I can't see it been the four sensors could it be the module?
Post #545891 Sun Jan 14 2018 9:44pm
Is it complaining about 4 missing ones at the front ?
Otherwise clear the codes and see what comes back.
Post #545945 Mon Jan 15 2018 12:03pm
Pauly14666
There is none fitted to the front
Post #545954 Mon Jan 15 2018 12:24pm
English HSE's have parking sensors at the front.
I know some foreign ones don't
Post #545957 Mon Jan 15 2018 12:33pm
Pauly14666
This car is in Ireland
Post #545987 Mon Jan 15 2018 5:39pm
Sharpy1980
I think Andy meant Is it possible that the car originally had parking sensors at the front but the bumper has been replaced for one without parking sensors as this is exactly what was wrong with my car and because the 4 front sensors were missing the rear pdc didn’t work either, if your diagnostics let’s you view live data maybe try and see what each sensor reads but if it won’t communicate with the diagnostic then it is possible the module or power supply/fuse could be at fault. Clickadeeclick
Post #546171 Wed Jan 17 2018 10:12pm
Pauly14666
When I scanned it it said that the four rear sensors are gone and noting about the front so if that is the case that there was front fitted I'm sure the computer would have a fault for the front aswell i had a bmw before the had this problem I changed the module and it was sorted any ideas were to get a module?
Post #546215 Thu Jan 18 2018 7:46pm
