![]() | Home > Technical > Refixing boot lettering |
Gandalf Member Since: 11 Sep 2017 Location: South Killingholme Lincolnshire Posts: 205 ![]() ![]() ![]() |
Be easier to just replace all https://www.powerfuluk.com/vehicles/range-...ering.html from £7 If it ain't broken down it soon will
Bullybrighton Member Since: 18 Nov 2017 Location: Maidstone Posts: 8 ![]() ![]() ![]() |
Clean it off the tailgate with wd40, gets any sticky glue off double time. I use a bit of old towel once I’ve soaked the glue and it works a treat.
I recently replaced mine as the edges of the lettering were weathered. I took the whole lot off with the wife's hair dryer and used the excess glue to take off the leftovers. I got lettering for about £10 and it came in a template so it all went on straight and took only a couple of minutes to to.
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
WD40. As Bullybrighton said. |
Mr M Member Since: 11 Nov 2016 Location: Liverpool Posts: 26 ![]() ![]() ![]() |
Excellent. I've ordered some new lettering and i'll give the residue on the boot a going over with WD40 until it's all removed. Thanks. |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
Autoglym Intensive Tar remover is the product I would use it takes the sticky residue straight off & readys the paintwork for the new lettering |
