![]() | Home > General > 2009 Range Rover Sport TDV8 Limp Mode Again. |
Get one of those IID code readers so you can note/clear the codes so you are not stranded. You should be able to pick one up on here and again sell it on here if and when the time comes.
cliffman007 Member Since: 05 May 2017 Location: Truro Posts: 9 ![]() ![]() |
Stevepd thanks for that can you suggest one? |
Theres a group buy on the go at the moment on Disco 3 pop over and maybe put uyour name down for a IID tool |
Hi All, sorry for the delay but it took a little while to discover that all my faults were down to the battery! Since getting it back on a lorry from half way to Scotland I have used it regularly and although various faults came up on the dash it worked fine. As the Greenflag mechanic who attended when I broke down suggested it was probably voltage I spoke to my battery man and he told me his son had the same problem on his and spent over £1000 trying to fix it at a Land Rover garage. In the end he fitted a new battery and all his problems were fixed. So I did the same, got a new battery and since then not a fault code anywhere in sight!!! Last weekend I did a 550 mile journey and it was perfect.
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
It`s only about £20 cheaper. Steve. |
Yep you will not get much discount on them at all |
