Home > Technical > Suspension
Daver
Suspension
The red warning light indicating suspension fault has popped up but still goes up and down as normal help would be appreciated
Post #544597 Tue Jan 02 2018 4:01pm
Tim in Scotland
Check that all your rear lamps are illuminating - a failed lamp can throw up strange fault warnings 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #544604 Tue Jan 02 2018 4:41pm
Cymruambyth
Wales
Do you mean this one but in red
 Steve.
Post #544617 Tue Jan 02 2018 7:58pm
its might help if you complete your profile with car year/engine/model.
Do you have oil on the floor under the car.
Is there a tank under the bonnet on the drivers side, with yellow cap, by air box ?
Is the level on Max line ?
Post #544618 Tue Jan 02 2018 8:14pm
Cymruambyth
Wales
Sounds like the same as my intermittent issue. Does it say max speed 30mph? Steve.
Post #544623 Tue Jan 02 2018 8:48pm
lkefc84
I am also getting this intermittently.
Mine changes between orange (which disables the off road / access height selection), and red which just says stop the car and engine safely. Neither affect the drive of the car. Mine is a 2007 (56) TDV8.
Would be interested to know if anyone has any further info on it... 2007 TDV8 HSE.. beep beep!
Post #544645 Wed Jan 03 2018 9:54am
PC76
have a look at your tyres. other members have had a similar issue and found it to be un-matched tyres. Same size tyres from different manufactures can have different diameters. this is picked up by the ABS/Speed sensor since one wheel is rotating at a different speed to the other and throws the same alarm.
i guess that duff ABS sensor would possibly throw up the same....
Post #544775 Thu Jan 04 2018 12:41pm
Gmanboyo44
United Kingdom 2007 Range Rover Sport TDV8 HSE Tonga Green
Suspension red warning light
Had the RRS MOT'd yesterday and it passed with flying colours. However after driving away from garage the red suspension warning light came on. I took it along to my RRS man but he couldnt get a code to cleared the light with two seperate diagnostic machine.
The car drives perfectly does anyone have any ideas of the potential problem.
Thanks
Post #546731 Thu Jan 25 2018 3:24pm
