![]() | Home > General > Foggy Headlights |
Chunk11 Member Since: 02 Jul 2017 Location: Manchester Posts: 47 ![]() ![]() ![]() |
I have added a photo to give you an idea. It was worse than this before and had improved slightly when I came around to take the photo. Range Rover Sport 2010 3.0 TDV6 HSE in Black
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
mine was a bit like that in the snow which is extream conditions.
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
I had this on a previous vehicle, it's caused by moisture getting trapped in. I removed the headlight and drilled a 2mm hole on the bottom of the clear lens in a bit not noticed or likely affected by washing/rain. It cleared up overnight and stayed clear with no other issues.
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
As per handbook -
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 403 ![]() ![]() ![]() |
Most newer cars have a sealed headlamp which uses a semi-permiable membrane to allow for expansion and contraction of air in the headlamp cavity. On the L320 headlamps the membrane is a rectangular unit located just below the H7 highbeam auxiliary lamp opening. RH side headlamp unit shown below with the vent circled in red.
AVS-9 is the membrane size used on the L320 headlamps
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9030 ![]() ![]() ![]() |
The pre-facelift units had small rubber tubes to allow for venting the headlight unit. They still misted on occasion but it usually cleared with the light s on for a while. 2012 SDV6 - it's missing a couple of cylinders
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
I’ve had this occasionally and was wondering if it was a contributory factor to my intermittent issue with levelling of the adaptive headlights. Haven’t got to the bottom of that on3 yet.
take a cap off each light, and leave for a few days.
Okay will give it a go! The lights still work fine as the bit infront of the bulbs is clear. I think it is more of an OCD thing in my head that it annoys me as I know they shouldnt be foggy. Range Rover Sport 2010 3.0 TDV6 HSE in Black
If moisture is already in the headlamp unit it is not going to go unless you physically remove the moisture.
Smarttech Member Since: 11 Jan 2017 Location: West Sussex Posts: 424 ![]() ![]() |
Have seen this a few times with my headlights but never bothered me as it always clears within a few minutes of having the lights on. My rear tail lights do it every time it rains or I wash the car but never seen any water in them, they just fog up a little so never worried about it plus I read somewhere that it's normal and they will clear under normal use which they always have. 2017 SVR. SVO Scafell grey Ebony interior
I didn't notice this in the owners manual, that bulbs should only be changed in a humidity controlled room. ![]() There is so much water in them, need to get it out |
