![]() | Home > Wheels & Tyres > wheels refurbished by a main dealer invalidates warrenty |
In T&C of LR genuine warranty from new, Alloys are exempt from normal cover if any kerbing or damage has been caused, wrong type tyres fitted etc.
Josh Bear Member Since: 19 Oct 2011 Location: UK Posts: 60 ![]() |
That is where the lacquer is lifting off the wheel,,when water gets behind it it will lift even more,,,warranty issue but don’t get me started on LR warranty’s.
The main problem area I see here is that they were not refurbished by LR or I presume one of their recognised repairers.
Hi
Darbs Member Since: 03 Dec 2015 Location: Cheshire Posts: 96 ![]() ![]() |
Had all my wheels replaced foc under warranty. The corrosion under the lacquer was exactly the same.
If you can persuade a JLR franchise to replace your wheels that would be a great result. However you will soon be back in the same situation with white corrosion visible under the lacquer. Polished alloy protected by lacquer does not withstand year round use in our climate.
