Home > Faults & Fixes > Veru Strange Noise.
OceanCarl
Spain
Hi,
Did you get to the bottom of this noise?
-Carlos
Post #546756 Thu Jan 25 2018 7:11pm
crdixon2004
Hi Carlos.
Had a number of repairs including new idlers and pullies. However, it is the dreaded turbo problem which i didnt want it to be. So that is the next thing is to sort it out as it is a body lift job. So might aswell replace other worn things while the body is off.
Has anyone any suggestions of potential replacements that i may need to consider before the body goes back on?
Post #546797 Fri Jan 26 2018 9:00am
Stevepd
Get the belts done Thumbs Up 2006 2.7 TDV6 HSE in Cairns Blue.
Post #546800 Fri Jan 26 2018 9:32am
Paddi
The TDV8 has chain driven camshafts so no belt to change.
The front to rear brake pipes tend to be very corroded so change whilst body is off. 2008 MY Java Black TDV8 HSE
Post #546802 Fri Jan 26 2018 9:59am
crdixon2004
Thanks guys. I know that previously the brake pipes have been changed. I have noticed my front ARB is leaking slightly. I hope it is the seal and not the actual bar...
Post #546818 Fri Jan 26 2018 1:36pm
