Home > Maintenance & Modifications > IID BT Received what next |
CANROVER Member Since: 03 Oct 2015 Location: Ottawa Posts: 255 |
You can set global widows up and down, you can calibrate height to whatever you want and you can change a few other things. I used mine a lot at first but now it just sits in my desk drawer until I need it. The great thing is that when you need it it is there and can save you a considerable amount of money in the long run. |
Fri Oct 27 2017 6:39am |
steve.rrs Member Since: 27 Aug 2014 Location: devon Posts: 90 |
where is the cheapest place to buy one of these |
Fri Oct 27 2017 7:41am |
You’ll have to find that out fort yourself. I bought mine in 2015 so the prices and site may not be the same. The way it works though is silly. It’s made in Montreal, just 2 hours away from me, but can I go over and buy one at a reduced rate? Noooooo. They idiotically set up a distributorship agreement with Bitool in the UK who inflates the price so it’s sent from Montreal to Bittool who distributes it throughout the UK to various stores and online sites and THEN, you buy from them. A scam just to inflate the price, pardon my language. |
Fri Oct 27 2017 6:04pm |
Read the manual incase you change something you shouldn’t 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Fri Oct 27 2017 6:33pm |
Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407 |
On their site there is a full list of what you can do with each model. Always do a backup before adjustments, just in case.
Fri Oct 27 2017 9:19pm |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 |
Lol Canrover, I had the exact opposite problem! I bought one direct from Gap Diagnostic thinking it would be best and ended up having to pay an extra £60 import duty when it arrived in the UK!!! 2016 RRS SVR Estoril Blue 2005 4.2L Supercharged Java Black - gone but was my first love. -------------------------------------------------------------------------------------------------------- If we all point our RR's in the same direction and accelerate at the same time can we turn back time? |
Fri Oct 27 2017 9:30pm |
PC76, mine's a 2005 SC so different to yours but when I bought my IID tool I added clock on dash, Nav on the move, updated the compressor software and 3 flash indicators.
Fri Oct 27 2017 9:36pm |
Scrumpy, Even after updating your vehicle, altering things, such as single lock/unlock, correcting speedo error for tyre size and adjustment, altering TV/Radio bands and frequencies etc, and routine error code checks, I use mine to alter suspension heights, generally for off road giving me the extra required sometimes for rocks and deeper water. there are things not switched on or in case of electric seats if you have 8 position highlighted altering to 10 on some models works as facilities already there and the correct switches. There are other examples of this, and a very useful part is live data, good for when on the move. John
Fri Oct 27 2017 9:47pm |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 |
Oops I have lost one pull close for the windows.. need to sort that.
Fri Oct 27 2017 10:12pm |
Quickly re one close windows.
Fri Oct 27 2017 10:16pm |
Thanks Johnski 👍👍 |
Fri Oct 27 2017 10:17pm |
PC76, The best thing to do is carefully play with it to see what's possible. There are a lot of things you can do with it. I use it on a need to use basis. So far, a lot of the things Johnski has mentioned I've already done. |
Fri Nov 10 2017 6:23pm |
That`s normal. All speedos read lower than GPS Steve. |
Fri Nov 10 2017 8:57pm |
£415 on ebay is the cheapest I`ve seen so far. Steve. |
