![]() | Home > General > Mud flaps for a HST |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
From what I`ve seen, you use the holes in the bodywork and then work out where to screw into the inner arch. No need to drill really, it`s only plastic |
Fitzyboywonder Member Since: 06 Nov 2017 Location: Manchester Posts: 5 ![]() ![]() ![]() |
Thanks. It’s a 2016 model and slightly different, the rear in particular has a stud (with no hole apparent and hence I believe drilling required).
Ah sorry, didn`t realise it was newer |
