Home > Faults & Fixes > another suspension knock. |
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 |
have you checked the center prop shaft bearing housing? |
Fri Oct 20 2017 6:27pm |
squizzel Member Since: 13 Jun 2013 Location: wednesbury Posts: 190 |
Hi Its had a new prop and bearing, and rear drop links as well. The knock can be felt through the steering wheel. The anti roll bar bushes seem ok. I have had it in the air and a bar under the wheels to lift them, to see if there's another joint gone.
Fri Oct 20 2017 7:23pm |
