![]() | Home > General (L494) > 2017 RRS Paint Imperfections - Advice Needed |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 ![]() ![]() ![]() |
I would do some research online and have a look for some professional Detailers around your area and ask if they would be prepared to have a look over the car and hi light any faults. They will have the correct lighting to inspect your paint, which I guess will be covered in swirls, sanding and even left over hologram tails from the dealerships poor polishing.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9051 ![]() ![]() ![]() |
If they are so small, why worry? What will you do when you get a stone chip on the bonnet? 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
jd2uk Member Since: 01 Apr 2017 Location: Kent Posts: 109 ![]() ![]() |
Because it's an £80k car and it should be perfect |
james5599 Member Since: 14 Jun 2009 Location: london Posts: 325 ![]() ![]() |
Yes it should be but the reality is it won’t ever be.....my Svr was pretty good but wasn’t perfect...
Ah, I see. It's just unreasonable expectations then. Nothing made by people is perfect. If you expect a perfect LR then I'd suggest you sell it now because it'll annoy the hell out of you with its imperfections. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Wow - unreasonable to expect a decent paint job on an £80k car? I’ve never had paint issues with any other car I’ve purchased and they’ve all cost a lot less than £80k. Maybe I should just get a refund and buy a Kia |
It depends how pedantic you’re being as to whether it’s unreasonable or not to be honest.
You should get it into the dealership asap if you have had it less than 6 months, but leaving it longer than 6 months then you cannot reject the car IIRC. I now know of 15 cars (Disco5's FFRR's RRS's Evoques and several Velars) that have been rejected because of poor paint finish, imperfections and general poor QC on mostly Solihull products. Most have been rejected within 2 months of delivery and LR had accepted that there is a problem on those cars - 2 of the owners were also rejecting cars that were replacements for rejected cars......... There is a huge QC problem with paint finish at Land Rover and they don't like to acknowledge it. I agree with you that the paint job and everything else on an £80000+ car should be £80,000's perfect it is a huge amount of money for most people to be spending on a car, however if you leave it too long you reduce your chances of redress so get it into them first, then take it to a detailer for a 2nd opinion or to see if they can correct the faults, I'm not sure many LR bodyshops are up to the standard of most detailers when it comes to paint defect correction. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
I think with LR you only get a decent paint finish if you have one of the special colurs, which will cost thousands of pounds more, undertaken by the specialist paint division, which is nothing like the way they paint/polish/check etc on new cars churned out. Always been a problem unfortunately, but surprising to find that one of the highest paint faults on cars as a % of those sold, is Lamborghini cars, and they cost three times ours. More expensive cars you would think are better, what's happening?
AHSFCA Member Since: 09 Mar 2011 Location: San Francisco Posts: 84 ![]() ![]() ![]() |
I've only owned 2 Land Rovers -- a 2010 Range Rover Sport and now a 2018 first edition Velar. The Sport had perfect paint in Santorini and the Velar in Corris Grey is also perfect, and I go over every square inch washing and waxing them. I once had an Audi with a fair bit of "orange peel" in the paint. My Velar has the best paint and finish I've ever seen. So I think it's unlucky if you get one that isn't flawless from the factory.
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
Unfortunately cars are painted in sealed rooms but contamination can still happen, unless they go all NASA and have a fully sealed rooms they make satellites in
scousefly Member Since: 25 Jan 2015 Location: sheffield Posts: 248 ![]() ![]() ![]() |
Was only £30K but I wanted perfection. I didn’t get it so took upon myself to amend. It’s still not perfect but 60+ hrs detailing it then a final finishing polish and ceramic coating and it was very good. It’s now got some swirl marks on it from washing as even the most pedantic washer will still inflict marks at some stage but it won’t take long to get them out and if I decide to keep I will put a different hard ceramic coating on probably fromGTechnic. Like others said u will never get perfect from any dealer in reality so just find a good detailer |
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1827 ![]() ![]() |
I agree with scouse get good detail done on it and you will be happy.
and
Are at odds, to me at least. If the only "imperfections" are so small you can't photograph them then I'd say that's a "decent paint job". Don't ever drive your RRS out on the road - there are stones and bird crap and all sorts of things that create "imperfections" out there!! ![]() On second thoughts - take it out on the road and give it a good drive. Perhaps take it along a muddy track or two. Drive it and enjoy it for what it is - a brilliant 4x4. It's not an oil painting to be admired from outside: it's a vehicle to be admired from the inside, sat in the driver's seat, revelling in its poise and ability. ![]() 2008 TDV8 - it was a labour of love and is much missed |
