Home > Technical > TDV8 loud whistling on boost
Sporticus
2006 Range Rover Sport TDV6 HSE Java Black
Hi everyone.
My 2008 TDV8 has a loud whistling/chirping noise on boost. Sounds like a referee blowing his whistle.
Turbos were changed less than 10k ago so Im hoping its not them.
No smoke from the exhausts and it doesnt do it when revved at standstill?
Could it be a perished pipe/boost leak? Or am I looking at body off bill again?
Post #535603 Sat Sep 16 2017 4:40pm
d-9
Cracked inlet manifold. Got any fault codes?
Might be a boost leak, but I would expect limp mode if a hose had gone.
Post #535606 Sat Sep 16 2017 5:16pm
Sporticus
No fault codes or warning lights.
Starts and drives fine. Ticks over fine.
Post #535610 Sat Sep 16 2017 5:52pm
Disco_Mikey
Broken exhaust manifold stud, and subsequent warped manifold...
Post #535614 Sat Sep 16 2017 6:30pm
Sporticus
How much am I looking at to fix?
Just took it out a run there. Wouldnt make the noise when engine was cold. Then started to do it intermittantly as engine got warmer.
Once fully up to temp was making noise all the time.
Post #535619 Sat Sep 16 2017 6:53pm
Four figures. Manifolds are £600 a piece and it's a body off job to do them. 2012 SDV6 - it's missing a couple of cylinders
Post #535622 Sat Sep 16 2017 7:00pm
Sporticus
I read the manifolds can be skimmed though so this would bring down the cost?
Wheres best place in Scotland to have the work done
Post #535624 Sat Sep 16 2017 7:09pm
Sporticus
And can the broken studs be visually spotted first before the body is removed
Post #535625 Sat Sep 16 2017 7:12pm
Disco_Mikey
Last manifold I has skimmed was £180 Shocked
Can usually be seen before lifting the body, but either way, it's a body off job to extract the broken stud and remove the manifold...
Post #535628 Sat Sep 16 2017 7:49pm
Disco_Mikey
Post #535630 Sat Sep 16 2017 7:50pm
Sporticus
What sort of bill am I looking at Disco Mikey?
I believe youre in Dundee? Im in Ayr.
Post #535631 Sat Sep 16 2017 8:02pm
