![]() | Home > Wheels & Tyres > How many miles do you get from your tyres? |
stornoway10 Member Since: 03 Feb 2013 Location: Southport Posts: 60 ![]() ![]() ![]() |
Dan
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9049 ![]() ![]() ![]() |
My Grabber ATs have done about 35k miles and have about 4mm left on average but the inside shoulders on all are more worn than the outside. They're down to about 3mm. They're being changed next Saturday for some AT3s.
You spotted those just in time with those tyre depths, as 1.6 and less generally means ending up with a ticket with 3-6 points and fine for each, the grip/drive with those on must have been hairy in the Rain? ![]() I replace mine at 3-3.5 depth, and generally cover around 29k to 31k miles per set. John RRS MY12 SDV6 HSE. Sumatra Black/Ebony & Walnut + Dynamic Pack, + Cold Climate Pack + Memory Pack, Digital TV/DVD, Premium Leather, Cornering Lights, Cooler/Fridge Box, & most Options. |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 ![]() ![]() ![]() |
Low profile Tyres only come with 7mm tread from new, so changing them at 3-3.5mm seem like you only getting 50% out of them. To be honest I'm not the sort to go hammering it into corners or hard around roundabouts, and even when i had a spirited blast i never had the tyres slip once, it was the outside shoulder that had disappeared that gave the game away. I have kept and eye on it for the last few months but something or other kept popping up meaning tyres where way laid till the next month and so on. Feeling the difference after having 4 new tyres fitted is night and day, I had a bit of steering wobble from 45mph onwards but it had been like that for such a long time i learned to live with it and ignored it.lol Turns out probably my fault for "washing off the old" wheel weights..lol. I've replaced the Conti's with Nexen Roadians HP's (not HT's), rated 'C' economy and 'B' for wet grip and 75db's. My old tyres were 'E' economy, 'A' wet grip and 76dbs. Feeling really smooth, and really quiet so far, but im comparing them against tyres that for at least the last 6 months have been worn out and on the limit. ( they passed the MOT like that in February. |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1068 ![]() ![]() |
My General Grabber ATs have now done 70,000km - like others worn on the inside and will have to be replaced soon but have lasted well. 07MY RRS TDV6
Copilot Member Since: 06 Jan 2014 Location: Sussex Posts: 31 ![]() ![]() ![]() |
I've found that by running summer tyres (Hankook Ventus ST) in the warm weather and replacing them with winter tyres (Vredestein Wintrac 4 Extreme) when the weather drops I'm getting a greatly reduced wear rate on both sets - my summer tyres were fitted brand new in March 2015 and 20,000 miles later (with the winters having done another 15,000) they still look like they've got 6mm left. I live down in the south east and although it rarely drops below freezing during winter, it gets up to 30 degrees every summer... I suppose it makes a difference if you take your local climate into account. |
