![]() | Home > In Car Electronics > Fitting a Pioneer car play double din unit |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
you won't have logic 7
R1CHD Member Since: 27 Aug 2017 Location: Warminster Posts: 32 ![]() ![]() ![]() |
Hi Andy
yes that looks like the one suitable for your car.
Not many se equipped cars with no sat nav fitted |
I'm not sure if it's a good thing or bad thing to be honest are the sat nav & 4x4 information etc much use? |
Sat Nav isn't much use. |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 ![]() ![]() ![]() |
If no sat nav screen then that is correct kit for HK install
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 316 ![]() ![]() ![]() |
What's the difference between that kit and one for a car with sat nav? |
The difference is the screen retention cable which is in this kit
I tried to fit the kit today with the Pioneer SPH-DA120 head unit but the plugs don't match up and instruction are vague here's a picture of the 2 plugs I can't connect and the back of my old head unit, any help would be great |
2 orange is optical network. Is that the car or adaptor end?
The plugs you see me holding are the vehicle looms, the plug to the right is the car look to the new adaptor that plug in to the head unit loom, so do I just ignore the 2 other plugs and just take a feed from the cig lighter? |
If the rest of the car works without the orange ones looped then that is fine.
Right the head unit is in and fitted thanks for the advice, the only issue I'm having is with the aerial I have really poor reception I have the Fakra Aerial cable adapter to din radio Fitted and the blue wire connected to the blue and white remote wire on the pioneer head unit but no reception I've tried connecting the blue lead to the 12v cigeretre lighter supply and the radios red and yellow power wires with no success |
