Home > Technical > 2010 range rover sport air suspension issues |
geoffsnook Member Since: 19 Nov 2016 Location: cardiff Posts: 1702 |
They do self level themselves when they go into sleep mode and also they drop a little istr but i may be wrong |
Sun Aug 20 2017 7:13pm |
rangeroverloon Member Since: 20 Aug 2017 Location: leatherhead Posts: 9 |
I've had a Range Rover sport before 2010 model and never had this issue before. The suspension seems quite hard on the frond and boats on the back. When it's left overnight the rear nsr drops to the same level as the nsf however the other side doesn't move. I've also put it back to acces height and taken the f26 fuse out and it still drops. I'm getting very streesed as the Warrentie companie won't help as there are no fault codes |
Sun Aug 20 2017 7:19pm |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2794 |
Welcome to the forum
Sun Aug 20 2017 7:25pm |
It had the standard alloys 20". The issue first started with access mode and would all of a sudden go into extended mode and after trying to put it into access mode it would come up with a message saying will raise when system cools. This was indicating the compressed was faulty so had it changed for a Amk upgrade. I have had RRS before with 22" alloys and never had any issues. The warrantee is with wms and they are a night mare to deal with as there are no faults stored |
Sun Aug 20 2017 7:33pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
http://mooreautomotive.co.uk/Land-Rover-Sp...tails.html Or www.rovertune.co.uk and see if they can suss it out and do battle with warranty company for you ?? Visitor from fullfatrr.com
Sun Aug 20 2017 7:36pm |
So i would have thought that the software for the new compressor was updated as well assuming you had a Hitachi compressor before |
Software has been upgraded. It is currently with a specialist at the moment and they are stumped. Can't find any leaks or any problems. All the height sensors have benn calibrated so without replacing everything I just can't get my head round it |
Sun Aug 20 2017 7:39pm |
