Home > Advanced Factors > R014147 OEM Timken Front Hub Bearing LR048083-RFM500010 £20
Advanced Factors
Site Sponsor
LR014147 OEM Timken Front Hub Bearing LR048083-RFM500010
£20 OFF USUAL PRICE THIS WEEKEND 18-8-17 - 21-8-17 £108 INSTEAD OF £128
https://www.advancedfactors.co.uk/index.as...h=LR014147
IF YOU HAVE A DISCOVERY 3 OR PRE 2010 RANGE ROVER SPORT AND HAVE HAD A REPLACEMENT GKN DRIVESHAFT YOU MAY HAVE A NUT WITH A LOOSE FIT TENSION WASHER WHICH HAS A DIFFERENT THREAD - THIS IS REUSABLE, IF NOT YOU WILL NEED CDU1534L NUT
THIS BEARING/HUB IS THE SAME ON LATER MODELS - ONLY THE NUT CHANGES.
HUB NUT TORQUE SETTING HAS BEEN REDUCED TO 230Nm / 169 lb-ft
MPN: KIT634, LR048083, RFM500010, LR014147, LR076692
Warranty: 2 Year Warranty
Make: Timken OE
Brand: LR6
£108.00 Inc. VAT
£90.00 Ex. VAT
 Paul Redding
+44 (0)23 8052 2776
paul@advancedfactors.co.uk
Post #533162 Fri Aug 18 2017 12:22pm
