Home > Faults & Fixes > HELP!! Washed car. Lots of Faults. Where do I look?
Chilly07
Australia
Hi,
I washed the car yesterday at the car wash. I did give the engine a quick wash too...I mean quick.
All good yesterday.
TDV8 2008
Got in car today and have the following faults.
Body Control
B1C62-14 (2F) Battery saver relay output circuit - General electrical failure - circuit short to ground or open
( on 18-08-2017 10:02:26 at 225740 km )
Engine TDV8
U0102-00 (2F) Lost communication with transfer case control module
Parking Brake
U0101-87 (F Lost communication with transmission control module - Bus signal/message failure - missing a message
( on 18-08-2017 10:02:26 at 225748 km )
Steering Angle
U0122-87 (2F) Lost communication with vehicle dynamics control module - Bus signal/message failure - missing a message
( on 18-08-2017 10:02:30 at 225748 km )
Suspension
U0102-87 (2F) Lost communication with transfer case control module - Bus signal/message failure - missing a message
Terrain Response
( on 18-08-2017 10:02:27 at 225748 km )
Transmission
The Body control was there prior to this...something I am reading up on.
The other faults I cannot clear. I am guessing I have water in a connector somewhere???
Any ideas where to look?
I have pulled plugs apart around the battery. All are bone dry and show no signs of water ingress.
Need to fix asap as heading to QLD on Sunday...well hopefully!!
Thanks
Chilly
Post #533119 Fri Aug 18 2017 2:14am
Chilly07
Australia
Ok...all fixed.
With help from Graeme on AULRO.com I have pulled the TCM apart and found water damage....much to my surprise as the area around it was dry, well perhaps not after finding the fault, and so where the plugs.
I have cleaned the board with MAF spray. I did not have anything else at home. I then lacquered the board.
I will purchase a new TCM as a long term solution...and lacquer it before installing.
Chilly
Post #533121 Fri Aug 18 2017 3:34am
scousefly
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
Whats
a TCM?
Post #533175 Fri Aug 18 2017 6:49pm
Transfer Case Module. It controls the transfer box for hi/lo range changes and centre diff locking. It lives next to the Engine ECU in a housing behind the battery box. 2012 SDV6 - it's missing a couple of cylinders
Post #533176 Fri Aug 18 2017 6:54pm
Paddi
Actually the TCM is the Transmission Control Module and is integrated into the mechatronic inside the gearbox.what the OP was referring to was the TCCM which is the Transfer Case Control Module.
Not trying to score points - I'm not that small minded! Just trying to help people avoid confusion because the workshop manual uses these designations. 2008 MY Java Black TDV8 HSE
Post #533181 Fri Aug 18 2017 7:15pm
Beer-soaked confused ramble. Ignore. 2012 SDV6 - it's missing a couple of cylinders
Post #533218 Fri Aug 18 2017 11:59pm
