![]() | Home > In Car Electronics > Technical Help Needed with Heated Steering Wheel Upgrade! |
Evo5man Member Since: 04 Jun 2017 Location: Skegness, Lincolnshire Posts: 222 ![]() ![]() ![]() |
Hi there,
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5045 ![]() ![]() ![]() |
If all the Multi Plug connectors were fitted and pushed fully home I am inclined to think the Clockspring you bought is suspect. As Buckster said there is only One Clockspring listed for a Heated Steering Wheel on a Sport Part No. LR018556
Thanks Buckster and Col,
Good News Col & Buckster!
Buckster Member Since: 05 Mar 2015 Location: Hampshire Posts: 1656 ![]() ![]() ![]() |
No worries Steve, glad you got it sorted. I have to say it is the best mod i have done, on a cold winters morning its awesome |
donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772 ![]() ![]() |
Glad you sorted it, but can you enlighten me as to what a 'clock spring' is/does in this context? |
I can give you a basic explanation of a clock spring but others could probably give you a much better technical explanation!
![]() Cheers Col |
Thanks! Yes, it makes perfect sense. I presume that it looks a bit like a clock spring, hence the name. |
Not sure if it looks like a clockspring or not to be fair |
The cars must be driven by clockwork, then, that's the only possible explanation! |
