Home > Technical > Front Brake pad wear sensor
eyespider
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Java Black
Hi I recently installed new discs and pads on my 2010 RRS tdv8
I believe if you let them wear down too low before doing the job you have to renew the sensor.
However I'm not sure what sensor to get there seems to be different part numbers.
On one site it says brake pad wear sensor for up to 19inch wheels.
My wheels are 20inch anyone know the correct part number for this application?
regards
Post #530255 Thu Jul 13 2017 2:16pm
I could understand you might need a different sensor for the brembo brakes
Post #530266 Thu Jul 13 2017 4:58pm
Appears to be only Two Listed SEM500080 or 6pot Brembo's LR019401
Post #530289 Thu Jul 13 2017 11:00pm
