Home > Technical > URGENT HELP NEEDED mis fire
Revaj110u
United Kingdom 2007 Range Rover Sport 4.4 V8 HSE Zermatt Silver
Hi guy new to the forum but am experiencing major issues with my range rove sport
To it started losing power when going up hills it will then die and need to be restarted.
It is now not idling right at all it's runni g around 500rpm and if you rev the car it will slowly decrees in rpm and die.
I have stripped all the inlet manifold to check for air leaks
Checked all coil packs with multimeter
Drained fuel system and put fresh petrol in
Fitted new maf sensor
Fitted new o2 sensors
Tested all injectors all fine
Still having no joy with this issue at all
The car just sounds like it's running on 4 cylinders.
I have a hawke eye diagnostic but it's not showing anything
The fuel pressure is showing 450kpa on ideal is this correct
And help is appreciated
Thanks in advance
Post #529843 Sat Jul 08 2017 6:00pm
geoffsnook
Does it have lpg
Post #529847 Sat Jul 08 2017 8:05pm
Revaj110u
Yes it does mate runs the same on lpg as it does on petrol
Thanks
Post #529849 Sat Jul 08 2017 8:31pm
geoffsnook
Does it have a lube system and would you know how many miles it has done on lpg as these engines are know to suffer with valve seat recession but there are other options to try first Thumbs Up
Post #529850 Sat Jul 08 2017 8:41pm
Revaj110u
I know it does not have the valve saver . I belive it's done around 40k on it since fitted I've had it about 8 months not and never had a fault with
It till now
If it is the valves what's the best way of checking them out I can pull the inlet again and boroscope down the ports not sure if i would see anything tho. I'm usually pretty good with cars but this range has got me puzzled as you can imagine
Thanks again for your help mate
Post #529851 Sat Jul 08 2017 9:00pm
GodivaNige
Compression test of each cylinder?
Post #529852 Sat Jul 08 2017 9:05pm
geoffsnook
Yeah check compression as you have tried a few things or you could try moving the coil packs around as see if that makes a difference how many miles on her and what's the service history like Thumbs Up
Post #529853 Sat Jul 08 2017 9:29pm
Revaj110u
Will the compression show duff valves ? If so that my first option in the morning.
I did try swapping the packs around but no joy
It would intitally run great for around 2 miles then start to play up but now it's every time I start the car it's lumpy and has no power . Although there is no smoke out of the exhaust . Would there be if the valves were shot
It has 5 years delarer service but independent dealers after that.
Post #529854 Sat Jul 08 2017 9:53pm
geoffsnook
Do the compression test at least it will rule the valve seats out Thumbs Up
Post #529856 Sun Jul 09 2017 5:43am
Revaj110u
Will do that first thing . Will let you know how it goes later on
Post #529859 Sun Jul 09 2017 7:41am
Revaj110u
Just done the compression test mate all showing between 160 and 175 psi
So that doesn't seem to be an issue mate
Any other ideas ?
Post #529873 Sun Jul 09 2017 10:53am
Tim in Scotland
I'm not an engineer or an LPG fitter and have only experience of diesel RRS but from reading posts on here about LPG there seems to be a variety of operating systems for LPG installations - is yours the sort that starts the car on petrol and then when warmed through automatically changes over LPG? If the misfire only occurs at that stage I would suspect either a leak in the LPG system or the change-over valve/s have a problem, or the control unit has failed possibly. Do you get the problem when only running on Petrol? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #529880 Sun Jul 09 2017 12:23pm
Revaj110u
Well the car getting better slowly haha
It's no no fer cutting out when on idle but as soon as you rev it over 4k it starts to bog as if there not enough fuel going to it
Any ideas guys
It won't allow the lpg to kick in but there was no difference when the lpg did work.
Now in just lost
Post #529889 Sun Jul 09 2017 2:55pm
geoffsnook
Can you get hold of a smoke tester and see if you have any air leaks or use a brake cleaner to spray around the intake area to see if there are leaks as you have no codes on it should not be rallt as you would then get some p codes as to be too lean or it may be a blocked fuel filter Thumbs Up
Post #529934 Mon Jul 10 2017 7:07am
geoffsnook
Tim as far as i know they all start on petrol then change over to gas Thumbs Up
Post #529935 Mon Jul 10 2017 7:08am
