Home > Faults & Fixes > Heating & Ventilation system not working - Help! |
DEVON Member Since: 14 Apr 2016 Location: Bolton Posts: 264 |
Fuse number 51 behind glove box , I think it is 10amps |
Fri Jul 07 2017 8:23pm |
Sgthomer99 Member Since: 17 Nov 2016 Location: Devon Posts: 12 |
Hi thanks for that advice but I've just checked the fuse and it appears not to have blown. Any other likely causes before I have to seek professional help? |
Sat Jul 08 2017 8:17am |
I'd also check the relays in the engine compartment,
Sat Jul 08 2017 9:10am |
phillh Member Since: 09 Oct 2016 Location: Hertfordshire Posts: 198 |
I had this problem when I first got my RRS. It was a faulty relay in the engine fuse box. There should be a sticker on the box which identifies what each does. Hope this helps. |
Sat Jul 08 2017 9:14am |
Thanks guys, how do I know if the relay is faulty I presume I can't tell just by looking at it. Do I just try and buy one any way from somewhere? Sorry for all the questions! |
Sat Jul 08 2017 10:04am |
I swapped it over with another relay of the same rating from the fuse box to check if the fan then worked, I then swapped back when I realised it was defective and ordered another from Land Rover. I think it was less than a fiver |
Sat Jul 08 2017 11:40am |
Hi folks update to issue and thanks for all advice so far. I have swapped fuses in glove box, negative. Found 2 possible relays in engine bay one with a big fan and one with arrows going into car, still negative after swapping them no fan working but lights on ventilation system. Now I'm stuck, will this mean a trip to a garage? |
Sat Jul 08 2017 5:25pm |
Hi folks just a quick update to the problem I had with my interior fan. She went in for a service with my local garage and they identified that a resistor pack in the dashboard had failed. They ordered the parts from Land rover and after fitting it, I was £185 lighter! At least it's fixed and I now have ventilation again!👍 |
Wed Aug 02 2017 11:43am |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1540 |
Thanks for the update. Always good to know the solution. Robin
Wed Aug 02 2017 5:36pm |
