Home > Faults & Fixes > Another Air con question |
geoffsnook Member Since: 19 Nov 2016 Location: cardiff Posts: 1702 |
Godivanige i will certainly try and do that over the next few days and post on here the inefficient compressor is sounding right at the moment :thumbsup |
Sat Jul 22 2017 5:47pm |
Right here we go then
Sun Jul 23 2017 11:23am |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
Yep, still the same conclusion, either slightly low on refrigerant or the compressor is worn
Sun Jul 23 2017 12:52pm |
I will empty the system first i think and see how much is in there with my mates machine at least then i should be able to eliminate either low refrigerant or faulty compressor thanks for all the advice |
Sun Jul 23 2017 2:56pm |
Well an update down to garage today and took out 220 grams so a leak is there ,So off with the front end of the car (what a bitch compared to a disco 3 with those extra rads) so got it off and wtf half the rad is missing cant believe it was holding any pressure so replaced and refilled pressure up around the 10 bar mark and evap temp down quickly to 3.5 so thanks for the help everyone and here's hopping |
Thu Aug 31 2017 5:53pm |
The cost of a new condenser etc is a bit of a blow but cheaper than a compressor. Glad you're sorted |
Thu Aug 31 2017 6:38pm |
Thanks but at £105 all in i cant complain can i |
Thu Aug 31 2017 6:53pm |
Once again thanks for the tips |
Thu Aug 31 2017 6:54pm |
Hocks172 Member Since: 01 Dec 2016 Location: Brighton Posts: 84 |
Just thought i'd put an update on my Aircon issues, beware long story.
Sun Sep 10 2017 7:52am |
wow it is nice to know they get sorted but can take some time |
Sun Sep 10 2017 8:06am |
Yeah perseverance is the word! Oh and money👍🏻 RRS Autobiography SDV6 19
Sun Sep 10 2017 10:20am |
Yep and best the pockets are deep |
Sun Sep 10 2017 10:45am |
johnsporttdv8 Member Since: 02 Nov 2014 Location: Cambridgeshire Posts: 16 |
Read this complete thread and learned a great deal.
Mon Sep 18 2017 12:49am |
I think you've pretty much solved your own problem here John, the compressor is dying as it can't efficiently compress the refrigerant at low speed. Given that its noisy as well confirms it is on it's last legs.
Mon Sep 18 2017 4:22am |
