Home > General > Park brake cables
ShooterNeil
Park brake cables
Park brake cables I need to replace mine as has to cut one side to replace the mud guards / backing plates behind the rear discs
Is it a simple job if so how do I do it 61 AB 5.0 supercharged rocket
07 HSE TDV8 with lots of toys EGR removed BAS remap
56 HSE WAS FULL OF PROBLEMS
Post #528610 Tue Jun 20 2017 9:04pm
Camelrock
Didn't think you could get the cables separately, thought they came complete with the actuator.. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
2018 Discovery 5 HSE lux current
1994 Dakar current
Post #528616 Tue Jun 20 2017 10:01pm
ShooterNeil
About 90£ each but there on eBay 61 AB 5.0 supercharged rocket
Post #528630 Wed Jun 21 2017 5:00am
Bodsy
Site Sponsor
You need to open up the actuator module which is underneath, just in front of the spare wheel.
It's fiddly, tight, but do able. Far easier on a lift than on your drive. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #528637 Wed Jun 21 2017 7:38am
Paddi
Looks like a bit of a mission but in case it helps here's a link to the workshop manual instructions:
http://www.rrsport.co.uk/gallery/albums/us...eplace.pdf
Good luck, hope you get it fixed. Thumbs Up 2008 MY Java Black TDV8 HSE
Post #528664 Wed Jun 21 2017 10:13am
Disco_Mikey
Os cable is fiddly, but easy enough.
Never done the NS yet...
Post #528676 Wed Jun 21 2017 12:15pm
ShooterNeil
Thanks that's my next challenge 😔😔😔 61 AB 5.0 supercharged rocket
Post #528703 Wed Jun 21 2017 7:23pm
SteveNorman
Both cables can be renewed. O/s is clipped into the actuator, the N/S is screwed in. You don't need to remove actuator or open it up to fit, just unscrew the large plastic nuts, then unclip O/S, or unscrew nearside.
regards
Steve
Post #529412 Sat Jul 01 2017 2:33pm
