Home > Technical > RR Sport S/C coolant pipe change HELP !!
jitzz
Morning All,
I need some of your collective expertise please, I have a 2005 sport S/C which has an issue with the coolant pipes. The pipes in question are the two pipes which run from the left hand side of the engine (as you stand in front of the car looking into the engine bay), and then run down the back of the engine and to the heater matrix. The part number for both these pipes is LR006147.
Land Rover have quoted me £252 for these - which seems rather steep - more like vertical !! Shocked
Can anyone advise me on how to replace these pipes - as the T piece has broken on one of them. I can get to the top connections but can't seem to figure out where the other end connects to......looks like somewhere under the supercharger !! will I need to remove it ???
Also, assuming I can change these myself, how do I go about bleeding the system of any air
Any help or advice would be very much appreciated !!
Many thanks
Jitzz
Post #527998 Mon Jun 12 2017 11:52am
