Home > General > HDC systerm fault ?
Rob199026
HDC systerm fault ?
Hi there need some help/advice on something
The misses has been using me ragney this week and for some strange reason the car flashes up Hdc systerm fault the car Lowers to access mode then after a few miles it go goes back to normal done this twice in a week
Any help be great
Rob Thumbs Up
Post #526843 Fri May 26 2017 5:07pm
Richard039
England 2007 Range Rover Sport Supercharged HSE Java Black
I've had the same thing happen to mine. After reading some other forums the fault seems to be the brake light switch. Strange but apparently true. The minute I get a chance to do mine I will let you know what happens
Post #526845 Fri May 26 2017 5:18pm
Rob199026
Hi mate
Had this done on mine already as a percaution was only about £50 to have done at my local 4x4 specialist going to take it back get it on there diagnostics machine see what's going on herd also that it can be brake light bulbs etc can cause it
Cheers for help
Post #526851 Fri May 26 2017 6:01pm
Richard039
I seem to remember something about that in the other forum. They said before you swap the switch check that both bulbs are okay. You just reminded me, thanks
Post #526865 Fri May 26 2017 8:10pm
Topsy
Wales 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Hi
Common fault with many causes. Can be rear bulbs and brake switch, mine needed EGR's. Much on here about it.
Post #526867 Fri May 26 2017 8:32pm
Richard039
HDR system fault
I finally bought a brake light switch, which seems to have cured the problem Very Happy
Post #533831 Fri Aug 25 2017 8:46pm
