Home > Technical > Rear door latch
GARYF123
Rear door latch
Hi, i have a 2007 2.7D. I only got it week ago and with all the work done and money spent in previous 12 months, thought i would be reasonably safe for a while, i was, a week! When locking doors with fob, the rear drivers side does not lock. When i operate handle, door opens and alarm goes off. Can lock it manually from internal catch and all other doors are fine. I stripped it down today as in right down to the nylon gears etc. Couldn't see anything amiss so rebuilt it. When operating cables manually, everything is fine but when put back on car, the movement is limited and not operating lock. I guess the motor is goosed but can anybody tell me different before i invest in a new latch?
Many thanks in advance,
Gary.
Post #526503 Sun May 21 2017 9:23pm
Ezituper
United Kingdom 2006 Range Rover Sport Supercharged HST Java Black
Mine did that intermittently, fixed it by lubricating the little lever inside the car.
Not done it since
Post #526505 Sun May 21 2017 10:48pm
adameverett
Been here twice now very common failure, front drivers then passenger for me. (lock it, and can just open the door) From lots of googling there are no user serviceable parts and its a swap out. £90 Had a indy spray it and fiddle with it for mot, fault came back in a couple of weeks.
Post #526509 Mon May 22 2017 7:29am
M3DPO
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Baltic Blue
It's the big motor in the photo that fails, they simply unplug and plug a new motor in, I may have a new one available if I can find it £10 posted, you will need to pull the brass worm gear off the end and push it onto the new motor. I always keep a spare as they fail regular Thumbs Up
Post #526510 Mon May 22 2017 7:36am
GARYF123
Sent you a pm.
Post #528611 Tue Jun 20 2017 10:21pm
NeilRRS
Not done it since
Which little lever?
Post #533888 Sun Aug 27 2017 8:17am
