Home > Technical > Having Passenger side mirror issues / fault
cbayuk
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Hi All,
Having issues with my passenger side mirror on an RRS 2008, the switch does move the mirror however only diagonally and not up/down and left/right as it should, its strange.
The seats work fine, the drivers side mirror is also fine.
Any suggestions? The motor has been replaced and also each side swapped just incase however still same issue?
Any advice will be welcomed! Thanks in advance.
Post #526431 Sat May 20 2017 11:46am
