Home > Technical > Dynamic Response Issues |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
Before you go to the expense of a new front ARC bar and pump, try changing the fluid reservoir. Inside the reservoir is a gauze mesh filter to protect the pump, if this is sludged up and restricted the pump will cavitate and lose ability to supply fluid under pressure to the system.
Sun May 07 2017 6:36am |
Edmundz1 Member Since: 28 Jun 2016 Location: London Posts: 13 |
Thanks for your reply, I have already removed the reservoir and cleaned it out as the gauze was dirty.. it looks pretty clean to me now so probably not worth changing? |
Sun May 07 2017 9:04am |
Sounds like the pump isn't putting out enough pressure. Try putting the car into low range and see if it does it then, you will be able to hold the revs higher without going fast.
Mon May 08 2017 7:37am |
Before you drive it in Low Ratio make sure that you are NOT on a metalled road, find a grassy / sandy area or loose gravelly area otherwise you can damage the transmission with wind up, driving on a lower friction surface will allow the wheels to spin out any wind up that may build up in the system. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon May 08 2017 8:14am |
How is driving in low ratio any different to normal ?
Mon May 08 2017 9:07am |
Is no one thinking it's the front stabilizer bar that's causing the issue? I only say this as it really knocks and bangs when you drive the car until the fault light comes on.. |
Mon May 08 2017 10:18am |
The fault codes suggest that it's the pump not giving enough pressure or that one of the valves isn't working as it should be.
Mon May 08 2017 10:39am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9013 |
The pump's output rate is at maximum by 1000rpm so no need to be in low range. 2012 SDV6 - it's missing a couple of cylinders
Mon May 08 2017 11:05am |
Thats is true if the pump is working correctly, but if the relief valves have gone weak the pump won't be able to maintain a high enough oil pressure, so reving the engine over 1k rpm will allow the pump to reach the required flow rate/pressure. |
Mon May 08 2017 11:28am |
Well I've managed to find a new pump on eBay for £200, has anyone changed the pump before? Big job? |
Wed May 10 2017 8:04am |
I would test first and confirm its faulty before pulling the trigger on a new pump, I wouldn't want you to spend £200 if it's not the pump at fault.
Wed May 10 2017 8:50am |
I've tried driving the car in low range with the revs high and fault light doesn't come on, which seems to me what everyone is saying is the pump isn't producing enough pressure. I've had the lower arms, bushes and wishbones replaced last year and all has been fine until recently. I just can't explain the knocking/clunking noise that occurs when turning and driving at low speeds before the fault light kicks in.. |
Wed May 10 2017 9:46am |
could you get the wife to drive the car and you record it ? |
Wed May 10 2017 9:55am |
cjohng Member Since: 26 May 2019 Location: newcastle Posts: 3 |
did this get resolved i've got the same symptoms and codes on mine |
Sun May 26 2019 9:23pm |
